tdonoughue
- The Woodlands, TX 77381
For me WOT is a matter of comfort. Rarely am I on water where I can do WOT comfortably (e.g. not bounced out of the boat). So when I am on flat water, yes, I have some fun with some WOT with the kids.
As to @Gthunter5 question... I would think that most of the wear/tear on the engine would be seal degradation due to heat (ultimately dissipated in the cooling stream), which would be higher at higher RPM. So I don't know that it is a matter of 'work' that the engine is doing as much as engine speed. The thing about taking off is that you are spending a lot of RPM but not getting a lot of distance at the beginning, which is the worst efficiency you can get. When you are cruising, you are wearing the engine at maximum, but also going maximum distance for that wear.
IMHO, etc.
IMHO, etc.
