Scoop
- NJ
- 242 Limited E-Series
Looking for some engine flushing advice. I have completely read the tow valve thread and have a good handle on the whole towing single engine issue - if it were only the occasional tow/single engine issue I would go with clamping off the line since this (hopefully) may never be required.I am more concerned with flushing the engine after salt water use. When I flush the motor after use and it is warm no water exits the through the hull side drains - all water exits via the various stern drains. If I start the engine cold it will flow through the hull side drains for a few minutes and then it stops. Perhaps diverted via thermostat?
I just got a new boat and don’t really want to modify it unless it is really needed. Here are some questions for the wise and experienced jet boaters:
Will flushing on a lift out of the water with salt away be adequate long term? Why would Yamaha design the cooling system this way if does not thoroughly flush the motor?
If I install the tow valves I will probably put them aft next to the clean out plugs but am concerned about accessibility.
For the guys using the clean out plug placement is it possible to install them via the removable oval cover (see photo) or is worth it to remove the much larger screwed in rectangular panel.
Finally, anyone have any long term salt water experience with the stock flush setup? Thought?
Thanks Scoop
