Tower and rear towing cleat weight limits?
Ronnie0471
Waterport New York
HO Impulse
Anyone know the wake tower and the rear towing cleat towing weight limits on the 215 ho? Didn't see it in the manual ? Thanks yall
BobJohnson
Highland Park, il
Chaparral
VR
I might get corrected on this, but I don't think you're going to find a answer to this question. I think if anything, it would be pounds of force ( not sure if that is the right term). Meaning, I weigh in at 200 lbs. I was on a tube while my wife was learning to drive pulling someone. We weren't going to fast (around 18 mph) and the tube and I were on the port side of the wake, when she decided to make a relatively sharp turn to port with the boat. Basically I came to a stop on the tube until the rope tightened up and snapped. So, my 200 pounds + weight of tube dead in water was equal to something much greater than just my weight. I was connect to our back tow hook. If connected to a tower, with a stronger rope, could have been a bad result for tower.
lets see if someone else has more of a definitive answer.
DJMattyT
Long Island, NY
Ive wakeboarded behind my 195 and im a big ass dude. Ive also pulled up 2-165lb guys no problem riding double wakeboarding
Boat Crazy
Lebanon Missouri
Do not know exact limits. I have pulled 3 skiers at one time from the wake tower and if you do a search, there are video's out there with 5 tubes being pulled at one time behind a Yamaha boat.
BryanW
Carmel, Indiana
SeaDoo
Challenger
Not sure on the limit, but I can say forward swept tower states skiers and wakeboards only (no tubing) the rear pylon, and cleat have no such warning. Which makes sense a tube with 3-5 on it can generate a lot more force that even the hardest cut from a board or skis. Found out that the tower on mine is made by Roswell, wonder is Scarab uses them as well? The Roswell guys/tower manufacturer would/could probably tell you if you can find out who is making it.
DJMattyT
Long Island, NY
Did you tie from wake tower ? Or rear cleat ?
I have always gone from the tower, I don't even connect the tube to the tow ring by the swim platform because the water from the jet gets caught up in the rope. I had to tow in a boat last weekend and used the tow ring by the swim platform and had no issues though
Eric195
Leander TX
HO Impulse
I weigh 215 and my wife pulls me wakeboarding all the time, no problem.
