Welcome to Jetboaters.net!
You can easily modify the front bimini legs so that they collapse to go under the wake speakers... then can be extended again after they clear.
I did this on mine, it was simple to do but I'm having trouble finding the original thread. More or less, you get some tubing big enough so that the original tubing will fit inside it. Get the end caps for it as well so you can bolt it the same as the original leg ends. Cut the original leg end off and shorten it as needed... drill a hole in the larger tubing and add a push button in the smaller (original) tube so it will snap into the proper position when extending it again. Voila, you now have telescoping front legs on your bimini.
I'd take pics but my boat isn't around right now...
the infinity 6100's came on my boat and w/the leg mod they sort of fit (still pressed on the bimini and stretched the fabric out)....upgraded to Pro80's and it was even worse, now I have Pro80's and MB8's and there's no way that it will go....
I ended up flipping the speakers so that they are on top of the tower and now I can use the bimini like it was designed the unfortunate thing is that using it w/the Infinity's for as long as I did stretched the material enough that it isn't really tight in between the back 2poles anymore
None? That's a bit strong. I agree the Pro80's won't fit but that's far from "none". I have four 6x9's under my tower. The AR230s already have collapsable Bimini poles and some speakers can fit without modification. I did a simple mod to my poles to allow them to collapse more but they still extend back out to original height.
My boat has the red Bimini on the left. The boat in the center is an example of another option
I apologize, my boat is an 07 & different layout than the 05, it appears from the pic above that the tower/bimini come close together in different places that they do on my boat....after I flipped my speakers over I measured and there is approx 8" between the bottom of the rear bar on the tower & top of where my Bimini should be at the closest point
Also, my feeling on this is very strong...I'm somewhat OCD & it bothers me that the fabric is stretched & "droopy" due to my mistake of doing this, so I'm sort of voicing my anger towards myself in my replies
if it's not for wake boarding you'd be perfectly fine with upgrading to stock speakers...you can even power them off the head unit if she won't let you play it very loud...getting rid of those stock speakers will make a world of difference....she might even enjoy the sound quality enough to tolerate you adding an amp
I know it would but I've built trucks and motorcycles in the past spending thousands of dollars and didn't love them anymore than I did in the past. I just sold a truck I put close to 80,000 dollars in and sold it for 6000. Not doing that again.
Without tower speakers, the cockpit speakers need to be played a lot louder when you're outside the boat. If you're floating or hanging out on the beach, tower speakers allow you to hear the music without blasting the in-boat speakers.
