Tower speakers
abamafan
I have a 2016 Yamaha 242 limited s e series and tower speakers do not work. Tweeters in tower work and led portion of the speakers work but no sound from speakers. Is there a fuse for them? I did check, amp has power. TIA
Do you have any other speakers laying around to plug in to see if the amp is sending a signal to the speakers. Any pictures of the speakers they don't sound stock 2016 had no LED. Maybe they ran new wire and it came loose or corroded if your in a salt water location.
They are wet sound rev 8’s. But unfortunately I don’t have any old speakers can a multimeter test for anything
If you measure the resistance they should be 4ohms or less
