not2fast
- Twin Cities
Anyone know the diameter of a 2016 212x? It should be the same from 2012-2016.
Did you end up getting the 2”? Did it work?I was looking at getting this rack. I have a 2019 AR210 as well. Are you saying you ordered the 2" adaptor? I want to make sure I order the right one.
Monster Wakeboard/Surfboard Combo Rack
Instead of a mirror that attaches to your tower, you could go with one that clamps to the frame of your windshield. This CIPA 02000 COMP Universal 7" x 14" Marine Mirror is what I use on my AR210.I need to know the OD of my wake tower tube so I can buy the right mirror. Anybody know? The suction cup mirror that came with the boat is a joke.
Thank you. I figured that out. I bought a PTM Edge 100 Pro. Same size as the one you recommended. We’ll see how that works out. Thanks again.Instead of a mirror that attaches to your tower, you could go with one that clamps to the frame of your windshield. This CIPA 02000 COMP Universal 7" x 14" Marine Mirror is what I use on my AR210.
That PTM mirror looks awesome. BTW, if it's about the same size as the one I have, it might fit inside the Plano Shallow Dry Storage Box (141250). That's what I keep my mirror inside when I'm not using it (e.g., when the boat's covered, or when we're fishing instead of wakeboarding).I bought a PTM Edge 100 Pro. Same size as the one you recommended.
yes, I believe the measurements are identical. Thanks!That PTM mirror looks awesome. BTW, if it's about the same size as the one I have, it might fit inside the Plano Shallow Dry Storage Box (141250). That's what I keep my mirror inside when I'm not using it (e.g., when the boat's covered, or when we're fishing instead of wakeboarding).
Any idea what a 2009 yamaha 232 limited tower would beI was looking at ordering a new surf rack this weekend and when I searched, there were many questions about tube sizes on various towers, but no concise thread with that information.
Here is what I found, feel free to add if anything is missing or incorrect:
- All E-series boats - 2 3/8 front and rear and 1 5/16" Bimini tube.
- All year 242 LS and 212X - 2 3/8"
- 2014 and older AR240, AR230, AR210 and AR190 - 1 7/8"
- 2015 and newer AR240 - 2 3/8" front, 1 7/8" rear
- 2016 and newer AR192 and AR195 - 2 3/8" front, 1 7/8" rear
- Scarab 215 HOI - 2 3/8"
- The 1·7/8'' OD rear tubing of my 2019 AR210 tower actually measures 1.925'' (1·37/40''), due to the factory-applied powdercoat on the tower. Therefore, the 1·7/8'' aluminum shims that came with my Monster Tower Swivel Adapters do not fit onto the tubes. I had to order 2'' shims and then build up the tubing size with a few wraps of heavy-duty self-fusing tape.
Rear tube is 1 7/8’s if ordering a Monster rack get 2” shims.2017 AR210?
