Welcome to Jetboaters.net!
View attachment 217088Also this step says the first post should have 12v. But it does not the lower one does. But on my functioning jet ski it’s the same way. And that one runs fine…. And now there is a check engine light…..that wasn’t there before
Well I’m at a loss any ideas guys? I’ve appreciated the help so far. Also if I switched ECU from my running jet ski to the and one, to see if it would start with that ECU. Would that cause any issues
