Sacamano
- Milwaukee,WI
- Limited S
I have a Shoreland'r trailer and the disc brakes are rubbing. There is a small amount of brake dust on the rims and the hubs get hot during short trips. I pulled the wheel off and things look pretty clean with no rust. The rotor was in fact rubbing, so I pushed the piston back. I wanted to pull and lube the pins, but the pins, which have 7mm hex heads, would not budge. I did not want to force and break something. I also noticed a couple of small holes in the piston dust boot.
Anyone have any experience or advice? Link to manual: http://www.boatmateparts.com/manuals/manual_5_20121217072638.pdf
