Welcome to Jetboaters.net!
looking for suggestions on location to mount a transducer given the hull design of the FSH 190 and perhaps how the wire was run from the console to the transducer
I had to google what a transducer was...never heard that word before
"a device that converts variations in a physical quantity, such as pressure or brightness, into an electrical signal, or vice versa."
That is what google's definition is. What exactly is a transducers purpose? This is my first boat, obvious I went with the Yammer Jammer. Is a transducer something I need to add to my mod list?
For boats, simply put, the transducer is the device that sends sonar signals down to the lake bed in order to detect fish, stumps or other under water debris and depth readings and usually a water temperature. The transducer is usually connected to a chart plotter or fish finder or other devices.
So I played around with my portable transducer in different positions and found if I mount on stern a couple inches below the bottom line aft I get sonar at speed instead of slow idle if I mount flush. Any ideas or suggestions for getting depth at speed???
This is what I used. Been in saltwater for a year now. Everything comes in the kit to mount and is very easy. I strongly suggest it.
SEAWORTHY INNOVATIONS Stern Pad - Standard Size - Black - Screwless Transducer/Acc. Mounting Kit (not for Large 3D Scan Transducers) https://a.co/d/1c53699
It comes with a scotchbrite pad to rough the surface and then clean it with the alcohol wipe, dry and just uses the 3M tape that it comes with. There is enough surface area that it doesn’t pull away.
Just my two cents, been over 5 years and lots of days on water in the Pacific and I connected mine to my ride plate. Works at all speeds and no holes in the boat.
Yes we get depth at all speeds. Super Super Super important out here with all of the reefs and rock piles just waiting to meet your hull.
I think there's a little bit of a clip of the actual speed indicator from the GPS in the vid I posted to YT when I installed the Transducer. It's close to the end of the vid if you want to skip the install.
