Welcome to Jetboaters.net!
A couple of reasons:
1) The impeller spins one direction, which makes it so that the boat turns better that direction than against the spin. The same effect is had on prop boats (but more so); jet boats are not immune.
2) But it equally could be that you have your jet not aligned properly. Center the helm. Then measure where the jet is relative to the hull to see if it is pointing straight back. There is a little screw adjustment on the cable near the jet. Disconnect the jet, loosen the locking nut, spin out/in the adjustment and tighten the locking nut again. Then reattach.
Thanks for responding and the information. After I had read a few other post, I decided that this is a common concern. I will check the alignment of the nozzle. Thanks again!
It is most likely what @tdonoughue indicated in his #2 point. When I replaced my steering cables I noticed that it would turn harder to the right. Found that the jets were angled more to one side. Since the steering goes lock to lock it wasn't lined up properly. Center your steering wheel equally between right full and left full then center your jet and adjust steering rod.
Disconnect the steering cable from the nozzle , then rotate the steering wheel all the way to the right ,place a piece of tape on top of the wheel then rotate it all the way to the left and place a piece of tape on top of the wheel then rotate the wheel back to the right until the 2 pieces of tape are evenly pointing down to the floor , now secure the wheel with a bungee cord to hold it centered, then reattach the steering cable to the nozzle while being sure it is dead center, adjust the cable if necessary , your nozzle will now travel evenly both ways.
