The one on the right is the one we're shipping currently.Hey Guys, do you know which if these thrust vectors is the recently revised version? Thanks!
You really need the hardware for the twin engine installation. The cross member can be changed if you'd like to return the one you have with the old style cross member (if it is new). If used we can send you a new cross member that matches and you can swap in the field. Either way the bracket that is used to mount the underside of the device needs to be the twin engine version. You likely got the single engine version if you ordered a single engine unit. Please call my office and speak to Kelly about this. As long as you pay the shipping we'll be glad to swap any parts needed.Thanks @Scottintexas and thanks for the update @JetBoatPilot!
@JetBoatPilot I had the one on the left already (which i thought was your updated style base don your video reference) but now have a twin so I purchased another unit and received the unit on the right side of the pic which does not match. Is there anyway to receive a matching unit?
Thanks, Nick
Please reach out to my office at 850-867-1410 and ask for Kelly. She can get you going on this. Thanks!@JetBoatPilot Thanks so much! I actually already did purchase the correct hardware from you guys for the twin install so we should be good there. If you guys could send me the matching part for field swap that would be appreciated. Thanks for the support! order number 10362
