Upgrading to coiled 7 pin trailer connector
Bruce
Royal, AR
Years ago I grew tired of using a 5 pin to 7 pin adapter every time I hooked the trailer up so I cut the 5 pin connector off and installed a 7 pin connector in its place. Since then I have had the ground wire pull loose from the trailer twice.
Last week I decided to fix this issue permanently. I ordered a Bargman / DrawTite 54006-043 six foot coiled trailer connector. The cable has a long coiled section like an old corded phone which allows the cable to stretch up to 6' without straining the connections.
This is the new cable in use. (Click the thumbnail to enlarge).
I soldered and shrink tubed the wires. The color code was different from what was used for the original 5 pin connection. After some experimentation I arrived at
Connector Yellow -> Trailer Blue (backup light, disable brakes)
Connector Green -> Trailer Brown and Grey (both wires, tail and marker lights)
Connector Red -> Trailer Yellow (left turn / brake)
Connector Brown -> Trailer Green (right turn / brake)
Connector Brown -> Trailer Ground
The black and blue wires from the connector need to be capped off. I used shrink tubing to do so.
I spaced out the splices at varying lengths so that they would not be overlapping.
I installed (crimped and soldered) a ring connector on the connectors ground wire, drilled a 1/8" pilot hole then used a self tapping screw to secure the ground. I applied dielectric grease to the threads of the screw and both sides of the ring connector.
The factory trailer wiring harness was smaller than 1/2", perhaps 3/8". I used a section of 1/2" split loom to overlap the 3/8" factory loom and secure it to the connector's coiled lead. 5/8" split loom would have been better for for the coiled lead. I secured both ends of the split loom with electrical tape.
Then I secured the connector's coiled lead to the trailer with two large wire ties that are typically used by HVAC installers. The third wire tie has secured the brake lockout key to my trailer for several years.
I purchased the coiled 7 pin connector for $34 via Amazon. Unfortunately the price has gone up in the last few days. I had the soldering iron, solder, shrink tubing, split loom and wire ties already. My total cost was less than $35 and the upgrade took less than an hour. It would probably be less than 30 minutes to repeat since I now know the color coding.
For comparison this is the old connector that I removed which has been opened to take a peak at which wires went where.
I have debated on making the switch too. I have been holding back because I don't want to exclude any buyers when I eventually sell the boat.
Do any modern trucks come with a 5 pin socket without a 7?
4 or 7... 5 is the oddball..
my truck has both. not gonna complain :)
Do any trucks still come with 4 pin connectors? I guess cars might.
GM trucks come stock with 7 pin and 4 pin combo plug.
My truck has both the flat 4 and the circle 7. Stupid thing figures the 5 is entirely pointless.
Last boat had a flat 4 and my truck had a 5. Go figure, now I have adaptors out the wazoo.
Why not use one of these?
I did not want all the extra wire hanging around or the increased potential of theft. Or perhaps I should just admit that I like soldering.
This adapter with the factory wiring secured to the tongue would be a quick, easy way to solve the same problem.
it is a pain remembering to put the adapter back on each time I retrieve the boat. you know how many times I've pushed my trailer in reverse with the brakes fully locked up....lmao
like why am I hearing this weird noise as my trailer is hopping up and down. hehe
I'm gonna cut mine and put the 7 pin on.
I think most modern trucks with factory tow package have both. This is what my Ram truck came with...
I cut the 5 off and put a 7 on before i took delivery. Bruce, i would suggest turning the self tapping ground screw into a 1/4in through bolt for long term reliability. Cam.
I got tired of jacking around with those flimsy 4 and 5 pin plugs this spring. I hard-wired a big 7-pin plug connector to all 3 of my trailers.
Reviving an old thread here-
I have a 2014 212 and shore lander trailer.
I currently have a 5 pin connector with 7 wires from the trailer going into it.
I often use my orange lock out because with the adapter I have it doesn’t disengage the solenoid when in reverse like it is supposed to.
I’m am totally down to cut the old one out and use a coil style exactly like @Bruce did. I’m just not sure what wires go to what on the new round 7 pin.
Any help would be appreciated. Thanks all, below are pics.
@Ratket, the 5 pin to 7 pin color conversion is in the first post.
@Bruce
Mama always said I was special...
Had to re read the wiring configuration like 3 times.. cause I kept skimming past the first one and it was the one I was most concerned with lol
Same here. I have more adapters sitting around than I care to admit to. Never had a tow vehicle with the 5 pin output though. All have either been 4 or 7 or both.
If/when I add brakes to this trailer, I'll be moving to a 7-pin connector. The adapters always seen to fall off, or otherwise get disconnected.
