W3bexec
- Greeley, CO 80634
Hopefully the experts here can help me understand this, I so appreciate this site! I'm new to jets and obviously new to troubleshooting this kind of stuff. Had the boat out yesterday and all was fine for most of the day until this started happening. I took this video of it specifically to post here as well as show the dealer if needed.
Gradually increasing the throttles up and all seems pretty normal until the port engine gets to 5K RPM. Then, just the port engine shoots up to 7-8K without any throttle applied. The quick throttle down at the end is me putting both levers in neutral. Here is the video of this:
I shutdown and checked the clean out ports. On the port I did find 2 very small twigs in there but nothing else. Afterward the problem still occurred. At that point decided to take her to the dock and wrap up the day. On the way, going about 4.5K RPM, the boat jolts a bit and I hear a clunk as see a quick bump up in port RPM, then goes back to normal. After that the issue of 5K racing up to WOT on port engine went away.
Also of note and you can see this is the video before the RPM race up occurs. Above no wake speeds the port engine is pretty consistently 300-500 RPM lower than starboard. Not sure if its related to this or not. Anyway, annoying as heck and will have a the dealer look.
