GTBRMC
- Waukesha, WI
- Boatless
- SX
http://leatherrestorationco.com/Thinking I will take the affected swimdeck cushion off the boat & take it to a vinyl repair place, assuming I can find such a beast in this area.
The ding in the gelcoat may wait a while. It is really not going anywhere. I may, or may not, try to fix that myself. It is on the convex rounded edge below and a bit forward (right in the photo) of the centerline of the speaker hole.
PS: Really, really mad at myself...just sick over this. I guess I just have to get over it.
That looks just about perfect, @Murf'n'surf ! I will look into them. Thanks a ton!
That would be great! But... I don't see it. Anyone have pix or can otherwise step-by-step this one for me?Usually there are two bolts and the rest of what you see are clips that you don't remove.
Remove the bolts and slide the cushion up and off of the clips.
There's someone that did swim platform speakers that shows the area. You need the swim platform backs removed, right?That would be great! But... I don't see it. Anyone have pix or can otherwise step-by-step this one for me?
Very good point... You out there, @Bruce?There's someone that did swim platform speakers that shows the area. You need the swim platform backs removed, right?
So we found this today. Looks old, so I guess we just overlooked it. Now to go about repairing it. Should I try a DIY vinyl repair kit from amazon? It's the bottom back corner never really seen, guess that's how it avoided us.
I would give it a shot. From looking at it, looks like it was scuffed up from something other than the boat. I'm saying not from removing and replacing the cushion. Because if this damaged occurred from removing and replacing, then I'm not sure the vinyl repair would hold.
