ralphsmithiii
- Tampa, FL
I just installed two brand new AGM 31's replacing the factory start and house batteries. I also built a solar panel charging solution using a 100w panel and duo battery charge controller. With that, I'm setting 13.7 measured at the battery terminals with the boat off but still connected to the solar panel. However, I'm only seeing 12ish volts on the Connext screen when I turn the switches on. Unless I'm not using my multi-meter correctly, is this normal or is there something I should be looking for? I did see there was a Connext voltage fix that @Mainah came up with and @swatski has done but I believe thats to have accurate readings between the batteries versus what I feel like I'm experiencing.
The solar controller I'm using is showing slow flashing green lights which indicated per the instructions a fully charge battery (float @13.7v) but I'm not sure why I'm only seeing 12.x at the Connext. Prior to swapping the batteries, I had no issues seeing 14.0/14.1 with the motors on.
I also just double-checked the setup once again before posting this. Turning the house/start batteries on but NO motor, shows 12.9/13.0 on the Connext. As soon as I turn the blower on it drops to 12.4x. Turn the motors on (30 seconds give or take) it shows both batteries at 12.4/12.4.
