vortex rotax fault code P1036
luisgnecco
Scarab
HO Impulse
Hello everyone
I have a 2017 scarab 195 vortex rotax. I found this fault code P1036. It has 73 hours and boat is running great. Any help would be greatly appreciated. Thank you in advance.
Did you mean P0136? If the code is P0136, I replaced the post-catalyst oxygen sensor and that code went away. The link below shows you a socket that you can use and provides a link to information on a relatively inexpensive oxygen sensor.
It does appear that there is a P1036 fault code, and one of the potential causes is a defective O2 sensor.
Thank you so much, I am going to replace the post-catalyst sensor. Do you think I should better buy the OEM or the aftermarket one?.
Thank you again.
