Wake board help
2devine
Farmington Ct
Just purchase Obrien wakeboard. It came with fins that have nylon washers. First question is where do the nylon washers go in between board screw, fin board? Second question-the thinner/lower prophile of the fin goes towards the inside or outside of the board?
The nylon washers go in between the board and screw head. The larger fin goes in the middle normally. Don't know what board you have but I cant see putting one small fin on one side...should be pairs unless it's a smaller fin for just the middle. There is no inside/outside on a board as it changes from side to side. Post a pic or the model you have.
It's an Obrien there are two fins. Just wanted to be sure the tapered end goes towards the middle?
