Wake Surfing with Trim Tabs
Rumbo
Arizona
I've searched the forums and can't find the answer to this. Will trim tabs list our boats at surf speed enough to shape the wake to surf if we keep our ballast at centerline? I've been listing our boat with the transom bag from Gantlin but it's a PIA to switch sides. I was thinking that listing it with trim tabs would allow us to keep ballast at the centerline so that all we would need to do to switch sides would be to swap the universal wake wedge and adjust the trim tabs. FYI...My boat is an AR240 and I'm using the transom bag, universal wake wedge, and a 750 lbs bag up front.
J-RAD
Orem Utah
I know @swatski did some experimenting with his trim tabs in surf applications on his AR240. I can't recall if he attempted mounting the ballast centerline...? In general his assessment was the the deployed tab lifted the rear of the boat hurting the wave. However, ballast placement and amount could be a defining factor.
swatski
North Caldwell, NJ
Unfortunately, it does not work - a tab down does list the boat but it also forces steering adjustment to counter the tab action - which in turn ruins the wake surface with jet thrust.
