Wake wedge surfing
Mjolsen74
Well. Finally surfed without the rope. Took wake wedge and 800lbs extra ballast (fat sac).
Port and ski locker ballast 100% too.
The wake looked messy but had great push and worked. Had a 4 min surf! Found best speed for me (200lbs) was 9.5mph after boat was “planed”. Had to move people up front and once it smoothed out back to back of the boat.
Mike
tdonoughue
The Woodlands, TX 77381
I see your boat is new. Next time when you are done with the rope, try to suck it up so you can get extra points here on jetboaters.net!
<kidding>
Congratulations on the ride!
J-RAD
Orem Utah
Nice work @Mjolsen74! It's such a cool feeling.
My prediction is that the "messy wake" you're referring to is the result have having the angle on the Wake Wedge set a bit too low. With that much ballast, you're probably only 4 full turns past level. It's purpose is to simply skim the surface; to low and it will plow.
Congratulations!
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
Also what water depth are you in? Looks shallow?
