I_squared_r
- Colombia/South FL
- 242 Limited S E-Series
My anchor light broke so I made this light mount with my 3D printer. A few things.. 1. In the photo, it's not sitting all the way down because the light screws I have are too long and 2. I bought a cheap drill bit from amazon and it broke 1" down when drilling the tower .. So I am running a wire to the outside without a quick connector so I can still put a rope around the tower. Learn from my mistake BUY A GOOD DRILL BIT. Anyways, it still works well, installs easy, and installs with a set screw. If people are interested then I can print a few.
I should've kept the pole for the old anchor light because I just realized that I could've cut it down and use it as a flag pole holder. I'm going to measure the diameter and see if I can find a stainless pole that fits tight in the base.
