topherbd16
- Marysville, OH
- 212X
Attached are 5 places/areas I'm looking to add a pop up cleat (or two if I add them in symmetry). Reason being is I carry stuff on that upper transom deck and don't want it falling off. Main reason is I have a 1000lb. Straight Line Sumo ballast bag and don't like tying it to the wake tower or running ropes up to the middle cleats on the sides of the boat (this gets in the way of climbing on and off the boat to swim, etc. Would like a pop cleat that is right there in one of these locations. However, access to these seem rather challenging. 1~3 have a double wall with hollow space. Will have to drill large holes for the nuts and tools to tighten from the back side then smaller holes to install the cleats from the outside. 4 and 5 seem very challenging.
A lot of Yamahas have cleats or ski rope attaments points at spot 1. Mine is on the lower swim deck.
Is this a terrible idea for it to hold a 1000 lb. bag from falling backwards (maybe 200 pound aft loading from angle of boat since most of it is supported on the deck)? We'll also use the cleats to tie up the roll up mats, tubes, coolers (and maybe anyone that doesn't obey the clean barefoot rule).
I'm not worried about doing the work myself, just more concerned about having a cleat pull out/crack the fiberglass after the fact due to using an area not designed for these loads.
Your thoughts, opinions and advice are appreciated!!!!
![Picture1.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/129/129577-aedd2f198600f8a8e83a7db4f0e57663.jpg)
