water flow from pee holes
mtnv900
Lake of the Ozarks
From the research I've done on this site it doesn't look like I have an issue but I want to make sure before memorial weekend gets here. I have always had a good amount of water flow out of the pee holes when in neutral. When I ran the boat for the first time my water flow was normal and everything was good. When I was coming back to the dock and put the boat in neutral I noticed I had no water coming out of the pee holes. When I put the boat in gear I had normal water flow. When I got the boat back on the lift I hooked up the water hose to test it out and I got my normal water flow out of the pee holes. I then decided to lower the lift and run the boat in the water to see what I got. No water out of the pee holes in idle again. I'm going to pull the boat out of the water next weekend and checkout the intake screens but since I get normal flow when in gear I don't expect to see any issues with them.
Like I said originally it looks like some people don't get water flow out of the pee holes in neutral and there is no problems but since this is not normal for me I thought I would get peoples thoughts about it.
adrianp89
Tampa Bay, FL
252SE
I don't get water of it when I flush with Salt-Away... prob doesn't help you much but thats all I got lol.
DBamaC
Hoover, Al
AR192
I'm not sure I ever remember getting no water out of the pee holes. I do, when idling, only get a very weak stream out of one of them.
Now I have to go to the bathroom. Thanks a lot.
tdonoughue
The Woodlands, TX 77381
I would look into it further. Check your jets and make sure you don't have something stuck in there or something. Like a little piece of plastic bag caught against the wall or something. Sounds like a partial block. I have always had at least some flow out of the pee holes. You may also find it clears itself on your next decent hi-speed run.
