- Acworth, G.A.
So, after buying the wake wedge and using about 2500lbs of ballast to make a killer wave. . . . . I've noticed when we are all filled up that my bilge pump is cycling and pumping out a few gallons or so.
My boat is wet slipped and never has a drop in it either at rest or during normal operation (with out the above mentioned ballast)
So this lead me to examine points of possible entry. The bottom swim platform is partially submerged with the weight mentioned above. . . . Though the 2nd tier nor the cup holders are never under water. The only other point of entry I can think of is the rear cleat which it basically under water when we are not actively under way.
Is anyone else having this issue?
