Liveto99
- New York Hudson Valley
- FSH Sport
The front cup holders had no drain hose attached. I forgot. I found this out when I put on the front platform. I had sealed the hole in the bottom of each when I did that. So that means any water that gets in them normally runs into the bottom of the boat. FSH 21. You twist the ring a little and it comes off then there is 3 screws that hold them in. I could not even find hoses for them up there.
