Anthony_bonanno83
- FSH
I just purchased my 2017 Yamaha 190 FSH and took it out this weekend. Everything performed nicely, except for ine of my speakers, kept rattling. No biggie. Afterwards I wanted to give it a quick wash. I immediately noticed water standing inside the boat and not draining from the 2 exit holes near the back? I removed the seats and looked inside. Water was leaking into the battery compartment on one side and I had another leak under the other seat as well. I noticed that the leaks where plain as day and caused by the placement of the drain holes. No seals or anything, just holes! I sealed everything myself because the dealership would have take days to repair. After fixing, I again sprayed my boat down for a wash. Still water was standing, no leaks though. Again I looked around and figured out that the one way drain plug was installed the wrong way!!! I had to reverse the entire hose on both sides. Very infuriating considering the amount of money I paid for a new boat! This boat should be completely water proof at the factory, consumers should not have to deal with this. Anyway if amyone is having problems with water not draining from the boat, check the one way flow valves on each side.
