CanTex
- Spring, Texas
- MasterCraft
- Other
Long story short...friend used waverunner, sucked up rock and trashed impeller and wear ring.
2009 Yamaha FX SHO model
I've successfully removed and replaced the impeller and wear ring. Now at the final stages of re-assembly I cannot get the jet pump assembly a fully install (impeller shaft appears to be binding on the intermediate shaft...some how!!!)
Actions / Knows:
* The splines on the impeller shaft are mating up with the intermediate shaft
* Impeller shaft was cleaned, no burrs or damage to splines, and re-greased
* The last 0.5" - 1" of impeller shaft will not seat on the intermediate shaft (not caught on alignment pins)
* Ran an inspection scope through intermediate shaft...no visible damage or debris
* Rotated engine by hand (using big nut on back side of impeller), not binding rotationally - bind appears to be on longitudinal axis
* Had my wife help with installation, I rattled and giggled the impeller shaft from the intake grate and she was gett'in on it - still no luck
* After multiple attempts it binds in same location
Questions:
* Is it likely that the intermediate shaft got out of alignment during the "rock incident"?
* Do I just really need to get after it? Video's I've watched show that once the splines are aligned it goes in with ease.
I've posted on this forum as the jet pump units are near identical for the waverunners and jet boats.
Thanks in advance, any suggestions or tips are greatly appreciated.
Actions / Knows:
Questions:
