Weak pee stream???
Ajax
St. Louis MO
Just for piece of mind. Is it normal not to have a pee stream at idle and no wake speeds? Once above 3000 rpm both streams appear. 09 sx210
bronze_10
Raleigh / Wake Forest Area..
i have a 2008 sx 230 and it does the same thing. I think mine is flowing but just not shooting out far enough to see it until it reaches 3000 or so..
jawsf16
Totally normal. My 08 sx210 had no stream at idle speeds...
Ajax
St. Louis MO
Awesome. Thanks.
Any thoughts on why depth finder does not read depth. I've tried everything I know to do.
bronze_10
HA! There are a lot of threads about that.. I just ordered a factory replacement that does both water temp and air temp but a lot of the guys here spent real money and replaced with after market stuff.. The factory ones never worked well.
Ajax
St. Louis MO
Figures. Really only complaint about the boat so just glad I know the river pretty well.
mattschepker
Saint Peters Missouri
same on my 2011 SX 210 no pee stream until 3000 rpms. as your depth finder not reading depths. Mines reading them but they're wrong. When we pulled up to the sandbar on Saturday it said we were in 1 foot of water at the back of the boat, when I was more like 5 1/2 to 6 foot of water
Ajax
St. Louis MO
Sucks. But glad I'm not the only one. See you drive by island today. That flag stands out.
RiverRat
Waukesha, Wisconsin 53186
AR192
I think I saw a tv commercial about this problem. Something about an enlarged prostate?
Someone had to...
mattschepker
we were not out on the river today. that's why I got the flag originally so people would know I belong to this website
mattschepker
Crazy. Could oh swore. My bad.
I have seen a ton of Yamaha's out on the river lately. do you have a flag or any markings on your boat so we would know it was you? we named our boat and its 3 buoys and a gal
buckbuck
Texas
Ajax, it is only a matter of time before your horn goes bad, too. Other than that, you are good to go.
Ajax
St. Louis MO
So weak pee steam, no horn, and depth finder does not read. If those are my only problems with the boat I can deal with that.
Good thing I bought that whistle. :winkingthumbsup"
Ajax
St. Louis MO
No markings yet. Have a few ideas for flag and some cutie marks(my little pony reference. I have three girls). Also down to about 3 name ideas. I'll have to remove safety stickers so they fit.
txav8r
Lake Ray Roberts, Texas
You also won't get a reliable pee stream when flushing on the hose. It takes higher rpm and water pressure to get much of a stream. Depth finder issues are a pretty easy fix. Norcross Marine is the maker of the depth sounder that we have. They manufacture this unit under several different names, but they are all pretty much the same. They will upgrade your unit to a temp unit as mentioned above or you can just get replacement parts for the existing. The folks there are very supportive and will help you troubleshoot it. It could be as simple as the transducer tilt angle, a disconnected cable, or it could be a failed head unit or transducer. If your getting the - - - reading, then it is a signal loss. If it is blank, that sounds more like a HU failure. It is common that they don't read well in disturbed water, when in reverse. Inaccuracy is not something they are known for, as they are pretty much right on the money. Keep in mind, that at sub plane speeds, your drafting 16" of water under the transducer, so if it reads 3', you only have 1.5' of water under your keel! Here is some contact info for Norcross, they have everything from entry-level to higher end sounders. Many guys replace them with chart plotters, others have them both, but whatever you have, knowing the depth is paramount IMO.
NORCROSS MARINE
Customer Service Department-Patrick (may be a different person now)
NorCross Marine Products, Inc
6881 Kingspointe Parkway, Suite 8
Orlando, FL 32819
(p) 1-888-766-7276 (f) 407-370-6880
http://www.norcrossmarine.com
