Liquor&Guessing
- Pittsboro, NC
- 242X E-Series
I'm noticing that the starboard side wet sound cone speaker (this is the tower speaker) has significantly less volume than the port side. Sometimes when I turn the batteries off then back on it will correct the issue and sometimes not. Anyone had this issue? Curious how you might have solved it. Not sure if it's a wire short or an amp signal issue or something else entirely different.
