Wet Sounds Head Unit
Mrbischoff
Maricopa, AZ
Question about wiring this radio... if I am reading this diagram correctly, the pigtail (labeled A) would only have the battery wire used if I am using an external amp. I will be using the RCA outputs to the amps. C89B0326-FB7A-4495-8ABE-F861C48F2A09.jpeg
TimW451
Sassafras River, Chesapeake Bay
Question about wiring this radio... if I am reading this diagram correctly, the pigtail (labeled A) would only have the battery wire used if I am using an external amp. I will be using the RCA outputs to the amps. View attachment 125172
On pigtail A, you’ll need 1 and 7 for ground and power. You may need 4 to turn on your amp, amp dependent. If you want screen lighting to dim with other lights you may have, then wire 10 also.
lgparra
Tampa, FL
AR195
@Mrbischoff how do you like the MC-2? Was it a big improvement over the stock setup? Does it fit well on the dash? Was thinking about getting one as well on my AR195. Any pictures would be awesome!
