SOLD Wet Sounds HT-AS10 powered subwoofer
slickus
Wet Sounds HT-AS10 powered marine subwoofer. Purchased new in December of 2015 and used it in the boat for 2 seasons. I removed the subwoofer before selling the boat. Works like new, sounds great!
Specs:
Powered 10" marine sub
Built-in 500-watt Class D amplifier
Reinforced fiberglass enclosure
Adjustable low-pass crossover (35-150Hz)
Frequency response: 20-150 Hz
Sensitivity: 95 dB
Thermal, over, and under voltage protection
Stainless steel hardware and aluminum mesh grille
Variable bass boost: 0-12 dB
Remote bass control
Built-in auto turn-on
Measurements: 14-5/8"W x 12-5/8"H x 12-7/8"D
$350 shipped to lower 48.
Thanks!
Where in the boat did you mount it? Just curious if it is an under the seat type application or what
Under the starboard backseat cushion on an ar190...fit perfect.
Lower price: $320 shipped.
