Wetsounds A-Link replacement or compatibility ?
vxooxv
Harrisonburg, VA
Has anyone found a 2.4 GHz audio transmitter/receiver that's compatible with Wetsounds A-Link? At 160 a pair they get extremely expensive when only last a season or two.
I've found several "universal" transmitter/receivers, I just wonder if they would work with A-Link.
2kwik4u
Georgetown, IN
Call Wetsounds and ask about warranty coverage.
I'm on my 4th season with mine and they are still working great. You should get well more than a season out of those.
To answer your question I don't know of any other product that works like the ALink setup.
vxooxv
Harrisonburg, VA
If I google 2.4ghz audio transmitter, I get several cheap(er) solutions. I'm not sure they are compatible with A-Link.
I also see that A-Link is is SKAA compatible so they are supposed to work with SKAA transmitters/receivers though I'm not sure anyone has both a transmitter & receiver in a single device.
2kwik4u
Georgetown, IN
I'll have to get to googling. I would guess these would still work, but I have no experience.
I used to voice/data cabling for large commercial spaces. We would often be asked to setup the PA system in a large building conference room, and things like that. I once used a set of wireless transmitters and recievers to blanket an entire room that was VERY cosmetically sensitive to wiring, and had NOT been planned out well for the intended use. They worked OK, but all required 120V power to run. Haven't looked for anything else since.
Be sure to post back on any finding you have. There are 4 A-Link devices in our group of friends, and we're 4 seasons in on these. I'm certain they won't last forever, and a lower cost alternative would certainly be welcome by all I'm sure.
vxooxv
Harrisonburg, VA
Most of us use A-Link too, however, I'm considering giving an FM transmitter a try. Fewer wires and more range. Our usual hangout spot can have anywhere from 20-100 boats and I'm often asked: "how can I link my stereo up to yours...". This would allow most anyone to do it on the spot. I read on some of the yamaha facebook pages this one has pretty good reviews. 12v too
2kwik4u
Georgetown, IN
Interesting approach. Not quite the same functionality as the A-Link, but should serve the purpose. We often trade "control" from one boat to another depending on the crowd, the mood, and the playlists available. So a single point to many wouldn't work quite as well for us.
With that said, I used an FM transmitter in the car for YEARS to get my phone output into the stereo, so it clearly works, and transfers the sound just fine.
