topherbd16
- Marysville, OH
- 212X
I like the idea of having the option for full bags on rear decks at 400, 800 or 1200 lbs pending on which one(s) I use and number of people on board.
What is the largest cylindrical or rectangular bag(s) you have fit on your transom deck and swim deck of your 212? Looking at these shapes for easy fill and I can use them in my friends older Chapparal on floor so Gantlin/Yamaha custom bag is not ideal for my situation .
A rectangular bag that is 24" wide will hang off the transom deck and I think a no go, but if it's 24" diameter, it can move forward a bit towards the transom seat backs and the portion sitting on the deck should only need 12" (I'm guessing here) of width footprint centered on the deck. I will tie it up so it doesn't roll off... or would it even move that easily? Not sure a 500+ lb. cylindrical soft bag will roll that easy, but I've seen crazier things happen.
I want to ensure I have plenty of weight when less people are on the boat.
Current setup:
Wanting to add more ballast option for when I have less people:
Current setup:
- 212x stock ballast, surf side tank full, other empty, ski locker 50%
- 400 lbs. of sand I can move wherever (25~30 lbs. increments)... 300 lbs surfside transom deck, 100 at bow
- Wakebooster
- 5 adults sitting in bow area, 3 on surfside.
- Adding 400lb for bottom swim deck 16x16x40 rectangular maybe
- and 400+ (cylindrical 20x20x50 ~525lbs or 24x24x50 ~800lbs or maybe a rectangle, many options)
