- Royal, AR
- SX
I am going to fabricate plywood walls between the under seat storage area and the engine compartment storage.
What kind of plywood would you use and how thick? My primary goal is sound reduction. I will be applying a dynamat type product and carpet to the plywood.
The materials that are readily available are 1/2" Pine Pressure Treated Plywood, AdvanTech 23/32 OSB Subfloor (OSB guaranteed for 300 days of water exposure) or 1/2 Birch Plywood.
I have worked with all three types of wood and am leaning toward the AdvanTech. It is a very dense OSB product and has worked well as the subfloors in my home. I plan to call around and see if I can find 1/2 Advantech.
Thanks for your advice.
