What sealant needed?
Ajax
St. Louis MO
What sealant should I use on top of the clean out tubes and under clean out tray??
I used 4200 by 3M, you really need to be able to remove those items at some point. In reality, none of it is under the water line so some clear silicone would even do the trick. This is just for the tray though, the tubes I don’t have anything on. Just tighten the clamps they should be ok.
Thanks. I was thinking the same.
Star brite sealants are also good. If you ever need an emergency fix for the hull of your boat, then this product will work. This silicone sealant provides an airtight and waterproof seal, so you can even use it in places underneath the waterline.
