Welcome to Jetboaters.net!
The Yeti 35 pictured above probably wouldn't fit. The ski locker door is 16" wide at the rear and 14.5 at the front. It's plenty deep, but it would be really hard to get in the door.
Considering EBAYing ours as not sure we will use it because its such a pain. Probably fine if you use it for a cooler full of the same stuff, or perhaps 2 different items....but we always have a big mix, and putting food in there really doesn't work.
I Have a 20 Hopper and find it's very hard to get into with larger items such as food. Even with just sodas it's kind of a pain. Supposedly they break in the more you use them, but I haven't had much luck with that. I also have a large AO cooler and it's super easy to get in to, but most of my stuff is swimming by the end of the day. The hopper's retention seems a little bit better. I really like the look of the RTIC soft sided coolers. The entire top zips open so you have total access to everything inside.
As for the main cooler, I use a Yeti 75 between the back seats. It fits, but it's a monster and takes up a ton of room, but it's all I have at the moment.
