1oz per stroke for a manual grease gun is allot... All the ones I've ever owned only pumped a fraction of an ounce per stroke. It would be nice to have one that pumps that much per stroke for my tractor...
Yeah, the initial 10 hour service calls for 1.11 - 1.18 oz which for my gun comes out to a little more the 37 pumps (
Amazon.com: LockNLube Professional Pistol-Grip Grease Gun: Home Improvement ). This is for the 2020 212s. It has a long tube connected to the housing to relocate the grease fitting to make it easier. Not all models have that. If not, then its allot less grease since you don't have to fill the line with grease in order for it to get to the housing. You would have to check that specific manual for the amount since I am not sure.
After the 10 hour, it calls for .20-.27 oz every 100 hours OR 6 months, so then I pump 7 pumps which is a little less than that.
That's all from the manual pic I posted above. I tend to just do what the manual calls out since I am not smart enough to improvise
. Lots of poeple do remove the hose and go direct, again I just do what the manual says. The service manual says to do the same.
If you feel the tube between the housing and grease fitting you will notice it getting stiff as you pump it full of grease. The 1st time I did it, I felt the very bottom of it (the end closest to the housing) as I pumped (a pain btw) so I knew when the grease reached the housing.
I actually did the same thing for my 2009 FS SHO (same housing and tube except with a supercharged engine) and never had a problem... At the end of the season I usually just pump some grease into the housing while I do the rest of my end of season maintenance.
Hope the helps!
