tdonoughue
- The Woodlands, TX 77381
For me, the important thing on the oil is to get the right weight and to make sure it is the hybrid (conventional/synthetic mix). The mix is important because once conventional has been in your boat awhile, switching to full synthetic (which does not wet the seals as well as dino oil) can cause the gaskets to shrink just a bit and you can wind up with little oil leaks. Brand is secondary as long as it is a reputable one in my book (I avoid the 7-Eleven, even super premium--sorry). So I have put STP, Shell, Castrol, and even the dreaded Mobil 1.
As to the filter, again, I go with the convenient brand name (which usually turns out to be Fram).
I have not had my oil tested (as some here have), but I have equally had no issues. Part of my calculus, though, is that I do change the oil annually and I don't usually put a mess load of hours on the boat each year. So I am changing the filter probably long before its time (and maybe the oil, too, but there is a time component there). There may be many better filters and oils out there and some use cases may indeed justify it.
Do have much respect for many of the folks above who put such research and quality into their boats. So I am not offering this to detract at all from what you see above, but rather to just add another viewpoint. (translation: don't flame me over the Mobil 1, huh?)
