Welcome to Jetboaters.net!
I've just used plain wheel bearing grease. If you are worried about mixing two types, I'd clean and repack the bearings. If you want to clean the bearings, use gas, WD40 or any solvent. Make sure you dry the bearings and then re grease. There is probably a YouTube video on how to do it.
I bought some marine grease (CRC). Looks to be the same grease (sea foam green in color). Gave a couple pumps into each bearing buddy to get ready for the trip. Is there a measurement of how far the spring is compressed when the right amount of grease is pumped in?
