Where can I order 4-tec 150hp parts?
LagoonaK
Syracuse, New York
I've searched this forum and the web with no luck. I have a 2016 Scarab 165g. Sucked up a rock. Removed it and the impeller and wear ring looked pretty good. A test drive proved otherwise. I'd rather not take it to my local dealer.
Scott E
Rush NY
SeaDoo
Challenger
Pwcmuscle.com will have what you need.
Slugger55
Jasper, AL
Agree, you have to look it up as a SeaDoo.
LagoonaK
Syracuse, New York
Thanks for the suggestions. I called PWCmuscle. They couldn't confirm an exact fit. Said the holes may be aligned differently?. I emailed Scarab customer support (boating@recboatholdings.com) and they told me what I suspected. 'Those parts are only available through BRP. Please contact your nearest BRP dealer for more information.'
Slugger55
Jasper, AL
Look it up as a 2012 GTI 155, Standard Rotax 1503... The parts will fit... (I'm sitting here with @ScarabMike talking about this) Just say'in....
JetTech72
SeaDoo
Challenger
If I'm not mistaking, wearing # 267000419 & Impeller # 267000602, is what you need.
You could probably use impeller # 267000639 which is from Speedster 150.
JetTech72
SeaDoo
Challenger
@ScarabMike ; I think the Scarab165g (w 150hp) uses 155mm wearing & impeller, not the 159mm.
