Topper232
- Marlton, NJ
- Limited
I need some help from the mechanically inclined members here.
I picked up my boat from the Yamaha dealer today that did the winterization for me. The mechanic came up to show me a bucket with the oil that they removed from both of my engines. There wasn't even enough oil to fill up a one quart container. He said that most of that oil came out of the oil filters.
He asked me if it had been a few years since I had the oil changed, and I said no. I have the oil changed at the end of every season by the previous dealer that I used. That's another story.
There is no oil at the bottom of the engine compartment and there does not appear to be any external leaks, so I guess the assumption is that the oil is being burned off. I did run the boat quite a bit this year and will guess that I have about 300 hrs.
The mechanic said that it could simply be a need for new head gaskets, which is a 4 hour job per engine, according to him. He did do a compression test of each cylinder and they were all fine.
Not being engine savvy, here are my questions/ thoughts
1. Is the oil being burned off if there are no signs of leaks?
2. If it's just a head gasket issue, does it take 4 hours to tear the head off of each engine?
3. Ironic that this is happening to both engines at the same time.
4. I never received any engine codes what so ever.
5. Is it possible that the previous dealer that serviced the boat last year did not put enough oil in?
6. Should these MR1's be burning any oil at all?
7. If it's not the head gaskets, what are the other potential problems I may be looking at?
The mechanic told me to just run the boat next season and keep an eye on it. That doesn't give me warm and fuzzies. Needless to say, I'm feeling a bit nervous as this is the first mechanical issue that I've had with the boat. I know everyone always states that these MR1's are bullet proof. Did I just get a bullet hole?
Appreciate your feed back.
Thanks,
Thanks,
