@Jmpicking
If your batteries are bad and won't charge the rectifier/regulator will get real hot while trying to charge a bad battery, I've experienced this. The hot rectifier/regulator may have melted your connector.
See if your connector looks like mine in this thread.
Here's how to trouble shoot, you will need a multimeter.
- Remove plug from rectifier and inspect
- Ohm out the connections in the connector to ground, the only one that should read to ground will be the black ground wire
- The red and black wires on your connector are the rectifier/regulator output and on the opposite side are the 3 wires coming from your stators
- Check the resistance between each of the pins from the stator 1-2, 2-3, and 1-3, the resistance should be the same between each one of them and the resistance should be low, around 1 ohm or below, if it's higher your rectifier/regulator is bad
- If all of that checks out you can check your stator output, put your multimeter on AC voltage and start the motor, measure the voltage between the pins just like in the previous set 1-2, 2-3, and 1-3 the readings between each of them should be close, I think mine was at 20 volts.
- If all of the above checks out, you are lucky because changing a stator will require engine removal
- Now you can check the regulator/rectifier, install a new battery, with rectifier/regulator plugged back in start the motor and rev to about 3500 RPMs and take a voltage reading at your batteries, you should see about 13 volts and it should not be higher than 14.5 volts, if it's not in that range then your rectifier/regulator is bad.
- If you think you have a bad rectifier/regulator you can swap the other motor's rectifier/regulator and do the above check at the battery, if it's not working you either have a bad rectifier/regulator or bad wiring on that motor
- To check the rectifier/regulator you can put it on the other motor and check the voltage at the battery with the motor at 3500RPM, if you are getting about 13 volts but no higher than 14.5 at the battery, then your rectifier/regulator is good and you have something wrong with your connector or wiring.
If you have a bad connector you can order from the link in my above thread, I can confirm that it worked on my 2010 SX210 with he MR1 motors.
If you do have a bad connector send me a message and I can give you a few tips on installing the connector.
