Solarz11
- Other
- Other
- Other
I recently just winterized my 212x for the first time since owning and I know not everyone does the antifreeze but I’m in MN and it’s peice of mind for me. For those of you that do antifreeze did I do this right? I rigged up a bucket to gravity feed the marine antifreeze, first started the engine and then introduced the antifreeze until it started to come out the jet pump. At that time I fogged the engine while it was running on antifreeze until it died. Later on after doing a little more research I come to find out that using gravity to feed the antifreeze is pretty much useless as it doesn’t cycle all the way through the engine. Is that correct? If so could the engines have gotten too hot while it was running and me waiting for the antifreeze to come out the jet pump? Any insight on the matter would be helpful. Thanks.
