nydave
- Limited S
Hello All yes another winterization question. It's that time. I picked up my oil, filter, plugs, oil extractor, antifreeze and watched all the videos. My only question is what pump are you all using to pump in antifreeze when winterizing. I dont want to get too small or too big of a pump so just looking for suggestions.
The previous owner also put in valve to shut off water intake to each engine in case you need to be towed or to run on one engine in emergency. I assume shutting these valves is the same as clamping off the water intake as shown in the video to flush antifreeze?
Dont think it is relavent but it is a 2015 Yamaha 242 Limited S.
Thanks all
Thanks all
