Wiring and ball size
rayg1022
We are getting a hitch for the AR190. can someone tell me the wiring is it a flat 4 pin. And the size of the ball for the trailer please.
Johmas50
Atlanta, GA
It’s a 2 inch ball but I’m not sure about the wiring. If your trailer has brakes it’s probably a 5 flat. If it doesn’t have brakes it might be a 4 flat. Maybe someone else will chime in with a better answer about that.
WetWillie
Mount Juliet, TN 37122
Correct 2” ball and 4 flat without trailer brakes that are first offered on the 195 I believe and most dual axles...
haknslash
Lake Martin, AL
Moomba
190's don't come with surge brakes. You would need to step up to the 192 or 195 to get surge brakes. For a 190 it will be a 4 wire harness. All Yamaha's are 2" ball trailers.
