oakley24
- Carnegie, PA
- SX192
I am planning out my second battery install, and I have a couple of questions. I believe I have the basics planned for the battery compartment thanks to @HangOutdoors thread, but want to add 4 LED lights, 2 in the engine bay and 1 in each aft storage area. Controlled by an additional rocker switch panel at the helm.
- Does this crude drawing look correct? Does the negative wire care where it's located? ie. can I just run that ground to the battery compartment instead of to the helm? Although my OCD may make me run that negative wire to the helm for organization sake, but still curious
- Is it OK to use the below type connectors to attach the lights to a single wire?
