tdonoughue
- The Woodlands, TX 77381
Undertook to wire the tower today...
Drilled some 3/8" holes:
I used some aluminum wire I had leftover from an electric fence install. Pushed that through the hole down to the next hole. Snagged that with a fishing hook and needle nose pliers. Then pulled through the wire.
Of course, it was about then that I figured out the wire I pulled was *just* too short. By probably a foot or 18". So I used that wire to pull through a second length of wire that was long enough... Ran those two sets of wires down the side to the joint in the tower:
Note the second attempted hole there. Apparently that part is solid aluminum.... So I had to try again a bit up from there.
Drilled another hole on the other side of the joint and down by the hull. Then figured out what time it was and dashed home for dinner (I was late).
More updates as they occur!
