Yamaha 2003 LS2000 LST 1200B piston
gonzaloak
Hi, one piston of my 2003 Yamaha LS2000 is damaged and needs to be replaced, but have been looking at Yamahapartshouse.com and they show 3 different type of pistons, Piston (0.25Mm O/S) AP , Piston (0.50Mm O/S) AP and Piston (Std) UR STD. On the other hand, at partzilla.com, there seems to be only 1 piston spec; Piston (0.50Mm O/S) AP.
Looked at the damaged part, but cannot identify which one is the proper one for the engine. Will appreciate if someone can give me some guidance.
gt5pilot
Lakeway, TX 78734
Measure the bore of the cylinder and compare it to the stock spec to see what size it is. The .25 & .50 are oversize that require machining of the cylinder.
Is the cylinder damaged? Will it need to be machined to get it cleaned up so the new rings will seat properly?
gonzaloak
Thanks.
Cylinder looks fine, just small scratches, but nothing in particular. Will polish it and measure the resulting bore. By the way, should I look to change the 3 pistons at the same time to avoid the motor running bumpy? The other 2 pistons are working fine and good compression, but surely have some minor normal wear, after all, are the original ones from 2003.
the MfM
The top of the pistons should have markings indicating if they are oversized or original.
I would reuse the pistons if they are in good shape but while you have it apart I’d suggest replacing all the rings.
Remember there is a front and back side to the piston!
