Want To Buy Yamaha AR190 - Pacific NM- 2010 to 2017- w 2 captains seats
River boat
SX195
Looking for used AR 190 with 2 captains chairs and low engine hours- 2010 to 2017- In Pacific NorthWest
2kwik4u
Georgetown, IN
AR's came with the bench seating. Most likely you'll have to find a custom modded boat, or go with an SX190 if you want dual captains chairs.
Good luck!
River boat
SX195
Thanks, Admiral
Still looking for AR190 ...will have to figure out after we find a boat.
River boat
SX195
Admiral Question
Would I be better to buy and sx 190 and add a tower or AR 190 and add a captain's chair?
Your thoughts
Enduro900
SE Michigan
SeaDoo
Challenger
Admiral Question
Your thoughts
Buy the model that already has what you want.....adding a tower involves reinforcements as does adding another captains seat.....By the time you buy a matching seat and nice tower i think the cost would be more than just finding a 19ft model/year that already has both IMHO.
BTW i’m in the same boat....wife wants a captains chair so that limits models/years for me to search for.
2kwik4u
Georgetown, IN
@River boat Here's what I would do......
Find an AR195S.....this is the only model 19ft hull that came with a tower AND dual captains chairs from the factory.
If you're willing to do some modifications, the next best option is to get an AR190 or AR195 and remove the factory bench seat and add a second captains chair. The aluminum plate to mount the port side chair is already in the floor in the correct spot, you just have to drill and tap it for the seat bolts.
Adding a tower to an SX190 or SX195 is a last resort option. The tower requires significantly more work to install. Then you STILL don't have the bimini or anchor light attached to the tower.
An AR with a second captains chair will look FAR more "factory finished" than an SX with a tower. Not that the SX will look bad, but aside from throwing a factory tower on there (which is absurdly expensive and hard to get) it will be obviously aftermarket. I personally prefer the "OEM+" look.
Good luck with the search and welcome to the boards!
