Brandonloos_21
- SX
For basic harness, $115. Anything custom would depend on what needs done.What is cost?
Hi are you still making these?Hi all,
I am making harnesses to either use different amps in place of your wet sounds dsp amps (if upgrading), or to repurpose the stock dsp amps in another application that needs RCA and speaker wire out.
Feel free to reach out if you need one!View attachment 166114View attachment 166115
Yes shooting you a message!Hi are you still making these?
This would depend on the tower speakers you’re looking into. I sent you a reply to your PM.Hi, I’m picking up a 222S and I’m planning to add to tower speakers, what would be the best way to go around this.?
Adding another amp for 2 tower speakers
Or
Adding an 8 channel amp ?
Thank you
Yes! Shoot me a text. 7248846120Do you currently have these available?
I’ll take one if it will work with my 2024 255DX. Let me know the cost and process to buy. Thanks.Hi all,
Hello 2024 222SE I'm looking to add or replace the stock amp with a 5 channel amp, 4 channels for 6 stock wet sounds speakers and add 10" kicker sub on channel 5, thoughts?Happy new year all, it’s getting to be that time of year when we all upgrade our boats.
I am still making and distributing the amplifier harnesses to be able to replace factory amplifiers with aftermarket versions!
If you’re in need of one shoot me a message here or text me at (724) 884-6120, lets get you setup for summer!
but is there already pre outs from the connext or anywhere on the boat maybe from the stern bluetooth controller?Yes and no. You can use this to connect as a pass through but you may still need a Audio control LC1. The head unit ( Conext screen) is sensitive to changes. Some have reports that it will shut down out put channels if the ohms are not correct. Needs to be 20kohms or more. So by adding a amp and parallel the signal to 2nd amp may be ok. You will need one that is male and female also zone out as need. View attachment 178906
Not on the 25’ boats. Our amplifier integration harness provides 3 pairs of RCA outputs and a remote wire.but is there already pre outs from the connext or anywhere on the boat maybe from the stern bluetooth controller?
sorry, mine is a 2025 222se. trying to get it better tuned with wet sounds oem department. do you have a diagram or pics of how it's connected to dsp amp? thank you.Not on the 25’ boats. Our amplifier integration harness provides 3 pairs of RCA outputs and a remote wire.
Using the OEM amp - you are stuck with the OEM tune.sorry, mine is a 2025 222se. trying to get it better tuned with wet sounds oem department. do you have a diagram or pics of how it's connected to dsp amp? thank you.
Just cut my wires yesterday wish I would have seen thisHi all,
Lol how did you miss this we have been making them since 2018.Just cut my wires yesterday wish I would have seen this
new to the forum and only started researching after cut the harness and ran into a problemLol how did you miss this we have been making them since 2018.
Are these still available? 22 Yamaha 252XE. Would like to gut the whole system and rebuild.Hi all,
