lokart
- SX
Only 17 hours on this jet ski. I had pulled the rear wall out of the front storage to have a look around. I was also running the ski with the water hose connected at the time. As I went to place the wall back, I had to tuck away the wiring harnesses and then bang, alarm sounds. High temp alert and YDIS 1 code. I quickly turned the water pressure up and the high temp alert cleared in just a few short seconds, but the YDIS 1 did not. I turned off the ski and now it will not start. Ski turns on, shows connext screen and instant alarm. I then went to look at the wiring harnesses to make sure I didn't unplug anything. I found a plug disconnected that looks like it has some sort of temperature probe strapped to the wire. I plugged it back in and still have the code. Disconnected the battery for a few hours, engine now cold to touch and still have error, won't even try to turn over. I ran the hose for just a minute to get cool water through it and still will not let me start it. Anyone have any idea what's going on?
